Het is nu do 05 nov 2026, 06:36
Plaats een nieuw onderwerp Antwoord op onderwerp  [ 49 berichten ]  Ga naar pagina Vorige  1, 2, 3, 4, 5  Volgende
BerichtGeplaatst: do 25 feb 2010, 21:30
Met andere woorden: vacuümslangetje van de actuator los halen, pluggen en kijken of de boost een hondsbrutaal karakter krijgt. Ik mag dat brutale wel :mrgreen:
Bedankt voor de tip! Zodra ik kans gehad heb om 4 meter nieuwe plastic vacuümleiding ergens vandaan te toveren even proberen.
BerichtGeplaatst: do 25 feb 2010, 23:06
die 2de methode is om de wategate zitting te testen op scheuren, let wel op dat je hier heeeeeel voorzichtig mee moet zijn.
BerichtGeplaatst: vr 26 feb 2010, 11:00
opel4ever schreef:
hee ik denk dat ik iets gevonden heb.
lees maar eens:
Boost creep and the LET
There are two sources of boost creep on the LET:
1. ECU pulsing of the wastegate (via the amal valve)
2. The spring of the actuator giving way before maximum boost is reached
Which one is more pronounced can only be found experimentally, and it depends on the make of ECU and actuator make/settings/age. It's easy to check it out, all you need is a boost gauge and some common sense.
Disconnect the pipe from the back of the actuator and plug it with a bolt. Keep it from swinging about with a cable tie. Beware: Now the ECU has no way of pulsing the wastegate, so the 1st gear boost restrictor doesn't apply. If it's a hot day and the temps go over the hill the ECU will be unable to cut down boost, so try this on a cool day, and only if you have a proper intercooler fitted. You'll see that max boost is reached quicker and it will be more brutal too! If you feel a big difference in driveability, that means that the ECU is working overtime pulsing your wastegate, so that might indicate something's wrong.
Next step is to disconnect the wastegate altogether - wind up the nuts several turns, so that the wastegate is kept shut irrespective of boost pressure. Now we're in danger territory, because it's very easy for boost to get out of hand and damage the engine with a boost spike. Avoid full throttle and keep your eye on the boost gauge. If the engine feels a lot more keen to rev, it means that the actuator is tired and it's half-open even when it's supposed to be shut. The diaphragms in the actuators don't live forever, and the springs do get tired after a few years. Get a new one and adjust it properly.
ik zou alleen voor stap 1 gaan, 2 lijkt me te gevaarlijk, mits je twijfels heb aan je acuator, de eerste stap kan je veilig kijken of je amal valve stuk is, of dat er iets anders aan de hand is waardoor je amal ingrijpt.
trickey
niet iets om zomaar ff me te gaan knoeien voor onervaren sleutelaar
Laatst bijgewerkt door calipeter op zo 21 maart 2010, 16:51, in totaal 1 keer bewerkt.
BerichtGeplaatst: za 20 maart 2010, 20:33
Nou schiet me maar lek. Linker kaartje was toen hij nog normaal deed, rechts is van afgelopen woensdag.
BerichtGeplaatst: za 20 maart 2010, 21:15
Sja, we meten de compressie hier wel eens in Nederweert. Een meting van 5 bar of minder op alle cilinders geloof ik helemaal niks van...
BerichtGeplaatst: za 20 maart 2010, 21:16
:o
BerichtGeplaatst: za 20 maart 2010, 21:28
Trouwens, heb weer te snel gereageert... Hoe wil je 13 bar halen op dat kaartje. :lol: Ga er maar 100% zeker van uit dat die meting absoluut niet goed is.
BerichtGeplaatst: zo 21 maart 2010, 16:50
kop tot uiterste gevlakt????? :lol: :lol: :lol:
let was 9,5 bar geloof ik he? of was het 9
BerichtGeplaatst: ma 22 maart 2010, 06:10
liever 9 dan 9.5 dan kan je iets meer met de turbodruk spelen :)
BerichtGeplaatst: za 10 apr 2010, 19:47
Het goede nieuws:
Cilinder 1: 14,5 bar, cilinders 2,3 en 4: 14 bar. Wastegate actuator is in orde, wel krijg ik nog steeds een ABS lampje wat naar verluid de wielsensor linksvoor is die tegen zijn grenswaarden aan zit wat wel kan kloppen want ergens in de linker voorkant komt een telkens wisselende hoeveelheid trillingen vandaan die soms vrij hevig kunnen worden.
Het slechte nieuws:
Er is een computer met VMAX chip aan gehangen, stukje rijden en hij trekt goed fel naar de 1 bar maar haalt geen 1,3 overboost. Waarschijnlijke conclusie: binnenwerk turbo aan vervanging toe wat op ruwweg €1200 neer moet komen :(
